Thread Tools Rating: Thread Rating: 9 votes, 4.22 average. Display Modes
Old 08-13-2017, 08:31 PM #16
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Originally Posted by Renegad44 View Post
This seems to be pretty typical with Toyota and Lexus....just had my wife's driver's door, and front passenger door lock actuators replaced a couple of months ago, they both went out within 2 weeks of each other, a 2013 ES300.....both replaced under our extended platinum warranty. Which brings the question, your rig is 2 years old, and the warranty doesn't cover that?
Don't have extended warranty, and I'm at 53k, so I don't think it would've been covered. I could be wrong, but even if it would've been covered I didn't have to wait 2 hours at the dealership!
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 08-15-2017, 04:19 PM #17
Renegad44's Avatar
Renegad44 Renegad44 is offline
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Renegad44 is on a distinguished road
Renegad44's Avatar
Neither did I.....
2011 LTD, Magnetic Gray Metallic, Solid Black Interior, LB22, NAV, Slide Out Cargo. Door Vent Visors, Hood BugflectorII, Sunroof Visor, full window tint, including moon roof. 3M Paint Protection Film, full front, side mirrors, A-Pillars. Remote Start. Every option available on a Limited, 20x9 KMC Chrome Wheels, 275/55/20 Goodyear Eagle LS2s, drilled, zinc-dipped, rotors. Owned a T2-SR5, T3-LTD, and now my T5-LTD.
Renegad44 is offline   Reply With QuoteReply With Quote
Old 08-15-2017, 09:36 PM #18
rjmarmjr's Avatar
rjmarmjr rjmarmjr is offline
Real Name: Robert
rjmarmjr is on a distinguished road
rjmarmjr's Avatar
Real Name: Robert
Thanks for doing this! I'm going to attempt the passenger side door soon. I've already had two go out. One was fixed under warranty but I'm past that now.
2014 Mag Gray TEP with KDSS - Icon Stage 2 - 275/70/17 Cooper S/T MAXX - Budbuilt Sliders with Bumpout and Full Tread - SSO Slimline Front Bumper - Smittybilt X20 - Factor 55 Goodies - Ellis Precision Shifters - Weathertechs
rjmarmjr is offline   Reply With QuoteReply With Quote
Old 08-19-2017, 02:41 PM #19
sgvT4R sgvT4R is offline
sgvT4R is on a distinguished road
For those of you who want a cheaper option than buying a new unit from dealer.. the 03-08 Toyota Solara door locks are the exact same ones. With the exception of the length of the cables which you can swap over.
I took mines out attempting to repair it, got frustrated with lining it back up and grabbed one from a 06 Solara and it worked perfectly. Might be same as other toyotas too, but the solara was the one I tried.
You can get new ones on ebay with a lifetime warranty
Door Lock Actuator Motor Front Right Dorman 931-411 fits 03-08 Toyota Solara | eBay
sgvT4R is offline   Reply With QuoteReply With Quote
Old 10-01-2017, 08:42 PM #20
Simonpk Simonpk is offline
Simonpk will become famous soon enough
great write up & I bought one of those little motors to repair my 2014 driver's door. - no problem changing everything out and took about 50 minutes. Now I have a problem - keyless everything works just fine - so that is progress. But with the key the locks won't lock if already unlocked and won't unlock if already locked. I took everything apart and put back together ok I thought but clearly not! Only thing I can think of is the shaft from the back of the key slot with the plastic cross on the end not engaging with cross slot on the actuator body - any ideas how to mate these up? Or is it something else altogether? Thanks for any advice.
Simonpk is offline   Reply With QuoteReply With Quote
Old 10-01-2017, 09:20 PM #21
Ryan_B Ryan_B is offline
Ryan_B is on a distinguished road
Than You!
Thanks for putting in the awesome work, and time that it took to write this up! Mine went out on my driver door (02 limited) and have been in need of replacing it but just haven't had the time to get it done. Will get done soon!
Ryan_B is offline   Reply With QuoteReply With Quote
Old 10-01-2017, 10:03 PM #22
ok - so I answered my own question - there is a 20mm or so blanking grommet on the door jamb - I took this off loosened the torx screw behind it & this let the lock barrel come out - I could then thread the shaft back into the actuator - took 3 minutes - hope this saves someone time in the future if their keyed entry doesn't work after an actuator change! Feel a bit stupid but then doing your own car repairs is always a humbling experience at times.........
Old 10-02-2017, 04:44 PM #23
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
You made me check, and turns out my own "fix" didn't get that part right either! Did you do this with the door panel off, or did you just back it out, then screw the torx back in while everything was "operable"?
Old 12-02-2017, 11:29 PM #24
mo8ftbl mo8ftbl is offline
Real Name: mo
mo8ftbl is on a distinguished road
Real Name: mo
I really appreciate you guys putting up all the pictures and information. I am just wrapping up my install. I'd say this took me about 3 hours. Removing the door took about 15 minutes, the actuator only took about 15 minutes, but putting the stupid panel back together...holy crap. Anyways i just wanted to say thanks. Also, i had the same issue with the actual key lock not catching the barrel. You do not have to take the panel apart.
Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!]-door1-jpg  Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!]-door2-jpg  Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!]-door3-jpg  Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!]-door4-jpg
mo8ftbl is offline   Reply With QuoteReply With Quote
Old 01-20-2018, 05:54 PM #25
waukeganlarry waukeganlarry is offline
waukeganlarry is on a distinguished road
This is why this forum is indispensable! Great writeup.
I just did both driver and passenger doors on my 2013. Toyota could do better with selection of these motors. So glad I found this forum soon after I got my 4runner.
waukeganlarry is offline   Reply With QuoteReply With Quote
Old 03-13-2018, 10:22 PM #26
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Great write-up mbumpus11...
and very valuable to our extensive library! 'Best to you',
rig, cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 07:10 PM #27
Riser Riser is offline
Riser is on a distinguished road
So I did this and it fixed the issue. However, my Interior door handle doesn’t work to unlock or open the door. I’m assuming it’s an issue with the cable, I just don’t know where.
I’m hoping I don’t have to open anything up again
Any ideas ?
2010 Limited, Magnetic Gray Metallic
Riser is offline   Reply With QuoteReply With Quote
Old 03-21-2018, 07:38 PM #28
Does everything look correct in this pic ? I think the metal piece with the “L” on it is causing my problems
Driver's Door Lock Actuator Motor Repair [step-by-step w/ pics!!]-3c68dbbe-2f8d-49eb-be46-208d20756c05-jpg
Old 03-25-2018, 04:09 PM #29
yeti73 yeti73 is offline
yeti73 is on a distinguished road
Thanks for this post. Called Toyota and they quoted $550 to replace the actuator. This is a better option for sure.
yeti73 is offline   Reply With QuoteReply With Quote
Old 03-25-2018, 09:34 PM #30
MSState09 MSState09 is offline
MSState09 is on a distinguished road
I had to take my door apart multiple times cause one little piece would be out of place and I’d be rushing and not notice.
Nothing in your picture jumps out to me as being out of place. Look at the OP’s pictures and compare it to what you have now. Also, put everything together outside of your vehicle and pull on the cables by hand to make sure everything works as expected (lock and unlock, unlock by pulling the interior handle cable).
If you can put up another picture with more light and a different angle and I’ll check again if anything looks out of place, or maybe someone else will notice something.
Good luck.
MSState09 is offline   Reply With QuoteReply With Quote
4runner , 5th gen , actuator , actuator motor , door lock
Door Lock Issues: Actuator or just Lock Motor replacement Mlynn 4th Gen T4Rs 15 02-01-2022 09:17 PM
Fuel tank removal step by step, DIY w/pics the great him 3rd gen T4Rs 17 02-15-2021 02:41 AM
Door lock actuator motor Jason11 3rd gen T4Rs 13 08-25-2018 02:29 PM
WTB: Front Driver side door lock actuator Golfinz For Sale: T4R Items 4 02-08-2013 10:21 PM
Driver Side Door Lock (Actuator?) streeter 3rd gen T4Rs 4 09-23-2012 07:53 PM
